Miss in # 4 Cyl posted by GCamp on July 21, 2012 at 07:48 PM
coil packs. Corrosion or a bad connection in the engine bay harness would be a good thing to check. Best to verify you really have spark before looking elsewhere - not hard to test either.
Pull coil pack, connector to car and insert a spare spark plug and make sure it's ground (wire around plug treads and then hooked to a good ground point). Start the car and see if the plug shows spark? Sometimes easier to do in a darkened garage....
